Plus my extruder is this and the other day I tried to make the spring smaller by forcing it with a pair of pliers to work with a new extruder chassis but I did not have all the parts so I ended up putting it back in this extruder but I forgot to re extend the spring :<i>missing/deleted image from Google+
No there is a grove
It’s printing better now but my bed screw that attaches the bed to the y belt is getting lose so that affects my print tremendously
In 2hrs or so I’ll show the test print in all its glory
Last time this happened I never realized it till it fell out
Don’t ever buy a acrylic printer I made my mistake
What mm is the extruder nozzle.
Also my printer it’s a hictop pursa i3 acrylic the parts break easily.missing/deleted image from Google+
And all that time spent balancing the bed is wasted because I have to remove the bed to fix the lose screw.
Dang that thing must print nice
You run smoothie or marlin
Oh I use a mks sbase board, it is based of smothieware and has a 32bit processor. I only have it because marlin was tedious at times, and the driver on my other board broke.
Problem fixed here is the first layer missing/deleted image from Google+
Yea 80deg I usually have supports.
Anyway thank you for the help I really appreciate it.
Can’t wait till I print a mount for a BL Touch and then buy one so I don’t have to worry about bed leveling.
Noice XD
OP always delivers missing/deleted image from Google+
It’s an extreme retraction test
