Can someone explain how I need to hook up the wiring and filament tubing? I have this 8 position connector that goes in the mix somewhere. Do I terminate all my wiring from the extruder to it and then run the jumper wire down to the bottom and send those wires where they need to go.
What is going to hold all of this up while the carriage is moving around?
2 wires for the hot end, 2 wires for the thermistor, 2 wires for the part cooling fan, 2 wires for the hotend cooling fan. 8 in total.
I put wire loom over the wiring, and use a hanger wire to give the bundle structure going up about 60% of the way. That keeps the curve nice and gentle, but also holds it up and out of the way.
Thanks @Eclsnowman Do you have that same photo only showing the entire wiring going up over the printer. Seem like will just lay down on me.
My finger in that photo is pointing to the hanger wire. It goes down into the vertical corner extrusion. That’s what gives it the structure going vertical.
@bcrazycramer I don’t, I won’t be home this weekend. I am driving to the cabin now.
@Eclsnowman Ah! I see that now. No worries. Thanks for the help. Have a good weekend!!!
@bcrazycramer thanks man. I need a little get away.
I really need to find a black fan! That white one is hideous!!!
