Can someone please direct me to some example config files for fans,
Can someone please direct me to some example config files for fans, so I can get my fans going. Switchs have so many options/versatility in the documentation, a get confused. I just want them ON whenever there is a print in progress. Thank You
Have a look at http://smoothieware.org/switch
All these options are what allow you to configure the switch you want.
You have 2 options :
OK, Thank you. Many edits and then resets later, I think maybe the lines should look like this but the fans (switchs) do not yet turn on during the print (I hope this is not bad etiquette to dump some lines of code here, sorry) : Switch module for fan control
switch.fan1.enable true #
switch.fan1.input_on_command M106 S255 #
switch.fan1.input_off_command M107 #
switch.fan1.output_pin 2.6 #
switch.fan1.output_type pwm # pwm output settable with S parameter in the input_on_comand
switch.fan1.max_pwm 255 # set max pwm for the pin default is 255
switch.fan1.startup_state true
switch.fan1.startup_value 127
switch.fan1.input_pin_behavior toggle #If set to momentary when the input pin becomes high the switch changes to the ON state,
and when it becomes low the switch changes to the OFF state. If set to toggle the input pin
toggles the switch’s state between ON and OFF.
The following should allow M106 and M107 to stop and start the fan, you can set up the fan on and off during print in your host software, e.g. repetier.
switch.fan.enable true #
switch.fan.input_on_command M106 #
switch.fan.input_off_command M107 #
switch.fan.output_pin 2.6 #
switch.fan.output_type pwm # pwm output settable with S parameter in the input_on_comand
In the example configuration file, there is an example fan switch module. If you do not modify it at all, it will do what you want.
Thank you all. Based on your comments I though the problem might be my version of Printrun (last revision was Feb '15). So I am exploring using LaserWeb (building a Laser etcher, not a printer). I AM encouraged to see amber LED lights beside the two small mosfets, never seen those before. Probably because I added: switch.fan1.startup_state true
