Can someone with an authentic smoothie board please share their config file that works with the K40 please? I have a 5x and just need a proper config file that works.
TIA!
TIA!
I’ll send you that once I get home in 11 hours
Should be the same config file for any smoothie user. “Authentic” board or not.
@Alex_Hodge I understand that. I am just asking for a file that is setup already for the Smooth-k40.
A friend of mine has the MKS SBASE board and used the Smoothie file and it did not work properly. He changed the config file to the one from the SBASE website and it worked so there must be a slight difference somewhere…
Sorry for keeping you waiting.
@Jean-Baptiste_Passan That just looks like a stock unmodified config file?
Nope, my file, with the switch added.
Unless I uploaded the wrong file but it should be good.
What are you hoping to find that way ?
Almost everything you have to modify depends on your machine (which motor it use etc…)
@Jean-Baptiste_Passan I am not “looking” for anything specifically. I just noticed that the stepper motors per/mm were same as stock config. I read that it should be set to ~157.48 or something like that. It just looks mostly stock at a quick glance.
I changed the motor to see if there was any enhancements over the stock ones
@Jean-Baptiste_Passan I’m setting up my Smoothie board as well. Can you tell me what your pin 2.5 and 1.31 are connecting to? are you using a logic level converter on both of these pins? Are you using the latest edge build? I’m hopping to create an easier to read diagram showing some of the different configurations. Thanks!
