Hi ,flashed the latest firmware on the mana se card from eleksmaker
if I save the g code in LaserWeb open it in test edit and add SO at the end of each pass it works fine. Ok for small files but a nightmare for larger ones
Hello all,
sorted thanks for all your help,it pointed me in the right direction.
the actual problem was that I searched for laser mode and it stated that the $31=1 command turned on the laser mode,
I know now that it is the $32=1 command
thanks again.
