Cant get the mosfet's to work
Hi All
I cant seem to be able to get the Mosfets to work. Any Ideas?
Can you describe ( both via text and pictures ) your wiring, and show us your configuration file please ? Thanks.
So I played with it and got it going. Thanks anyways
Thing to remember on the mosfets is only the negative leg is switched.
If you only connect the negative line to the smoothie, and use a external terminal block for the positive leg, you can switch multiple voltages just by using common negatives. I’ve used this on the big mosfets with one switching 24v and the other switching 12v though I could have done the same thing on the little mosfets amperage was low enough.
