Can’t seem to get my laser to burn when running a path as well as the test laser button doesn’t seem to be working on laserweb3. Everything is set up and running smoothly with any SVG I use but it will only run the path without the laser on. I have the Gearbest laser and its running on grbl. any hints on how to get the laser to work?
+Peter van der Walt It’s not the start/end code, if the LaserTest button also doesn’t work, as LaserTest is not using these settings. I say it’s hardware based (Grbl 0.8 / 0.9 jumper).
@Ashley_Wyld Please check the Eleksmaker/Gearbest Community for more details:
https://plus.google.com/communities/109476961016291692936
Thanks guys. I am going to check my grbl settings tonight because I am thinking something is wrong with the code. Possibly it didnt recognize the pin flip or the coding needs to be updated so it recognizes the laser
Are you guys saying that grbl 0.8 > 0.9 jumper may be in the incorrect position on the ardunio board? If so I will check that out tonight too.
Got the sucker up and running and making smoke. One happy camper. Thanks for the help guys!
