I cant swap the endstop (y axis)
Here is where it works,
# Endstops
endstops_enable true # the endstop module is enabled by default and can be disabled here
#corexy_homing false # set to true if homing on a hbit or corexy
alpha_min_endstop 1.24^ # add a ! to invert if endstop is NO connected to ground
#alpha_max_endstop 1.25^ # NOTE set to nc if this is not installed
alpha_max_endstop nc
alpha_homing_direction home_to_min # or set to home_to_max and set alpha_max
alpha_min 0 # this gets loaded after homing when home_to_min is set
alpha_max 200 # this gets loaded after homing when home_to_max is set
beta_min_endstop 1.26^ #
#beta_max_endstop 1.27^ #
beta_max_endstop nc #
beta_homing_direction home_to_min #
beta_min 0 #
beta_max 200 #
gamma_min_endstop 1.28^ #
#gamma_max_endstop 1.29^ #
gamma_max_endstop nc #
gamma_homing_direction home_to_min #
gamma_min 0 #
gamma_max 180 #
but I need the endstop at max not min for y-axis.
ALL I am changing is the beta section to
#beta_min_endstop 1.26^ #
beta_min_endstop nc
#beta_max_endstop nc #
beta_homing_direction home_to_max #
beta_min 0 #
beta_max 200 #
I have tried leaving the min values in, removing them, leaving nc in and removing that, a copy of a clean endstops config and just changing the home_to_max, but everything I try the board just refuses to reboot
all the SB does is click and wont switch on with just a flashing red light
I have to remove the sd card, put it in a micro to sd adaptor then put it in my laptop and edit the config.
after doing this about 30 times tonight I am starting to thing the biggest selling point of the SB with the config on SD is a PITA
anyone have any ideas why its not working, and is there a way to see any sort of log when the board wont boot at all after a config edit ?
war
