I had everything working well with BLtouch and 3 Point plane leveling strategy.
I decided to go to rectangular.
Now when G32 is issued, every time the blouch measures a point, the Z axis goes to home, which in my case is Max Z.
so it takes quite a while since my Z is about 600mm bu the time it does all the points.
When I had 3 point, when it measured one point the table only moved about 10mm then started to check height of next point.
Is there a setting i have missed somewhere?
leveling-strategy.rectangular-grid.initial_height 5 changing this value seems to have no effect.
Once the leveling is completed after a long time,
i noticed whilst first layer is being printed, bed leveling strategy seems not to be working and i do not see the z axis moving at all whilst printing the first layer.
