changing motor current settings but what about config override?
Hi all, I recently finally built my TEVO little monster, now I realized there’s a video on youtube by Design Prototype Test that apparently states that you need to rebuild the whole software because even if I was to change the alpha, beta, and gamma current to say 1.7 in the config file. the settings in the config-override file (which obviously also has the M907 command to set current) will override it and set it back to 1.5 (which is what it’s at right now). The config-override file when opened in notepad also states that to NOT edit this file. So therefore do I have to follow that video and reset the whole thing? I am worried about screwing something up. Thank you very much
if you want to use config-override, you need to set the right values for the values it covers. simply use M907 to set your current to 1.7, save, done.
Oh so I can change the settings in config-override even though it says not to edit the files? Sorry just want some clarification. so in M907, you mean as in say I connect to the smoothieboard via octoprint or pronterface, then type M907 X1.7 Y1.7 Z1.7, then after that type M500 to save it and that’s good?
Well, you don’t edit the file with a text editor, but you modify it with Gcodes like M907 ( and then M500 ), it’s what they are made for.
Oh okay, thank you very much!
