check out this super neat way of auto leveling using accelerometers.
it’s a completely solid state solution that seems to have solved the problems with both FSR and inductive sensors.
will be interesting to see what the accuracy is like.
https://www.youtube.com/watch?v=pgSxb4t1gLo
Worth the look
ok lets see it working, very Interesting.
This isn’t new. DeltaMaker tried using this 3 years ago, and it just wasn’t accurate enough. In fact, it’s exactly the same 3 axis accelerometer that we still put on the DeltaMakers.
I thought about this as well, but the issue is that there would need to be at least 2 high precision accels, one for the bed and one for the nozzle. Then one would need to calibrate them after manually leveling…and take into account thermal expansion (some accels have a thermocouple built in that is supposed to calibrate for this automatically, but they tend to be more expensive).
@ThantiK good to know i believe the MD3 micro runs this style system also. will be interesting to see how the new
SeeMeCNC machine goes.
@william_foster this system uses the opamp and one-shot though, which may make all the difference in the world. Just because it’s been tried, doesn’t mean not to try it again your way.
