Following after Frank Hermans work on getting a ChiliPeppr to run LOCAL I set out to try and do the same with RASPI and also a Linux Mint box. but running into DISCONNECT problems.
We made a video that shows the problem any help here will be so good.
Serial Port JSON Server always shows disconnected, However it does appear that some of the time we are actually connected and see the JSON strings in the Serial Port Console.
For testing I have just grabbed a DUE board and uploaded the lated TinygG2 code. So the Due is just hanging there with no shield.
The DISCONECTED problem is the same on Linux Mint Box and RASPI.
MAYBE ??
Frank Hermanhas made a local version by downloaded all the javascript library (modules) to jslib folder, and edited the source code of official http://chillipeppr.com to load his downloaded library.
But that library is 5 months ago. I assume the Serial Port JSON Server update some stuff. So library has not been updated.
This is the library Local ver import from jslib folder:
Just a guess???
This would be great to fix this than ChilliPeppr can fit into your pocket and go on to the airplane with you, Is just what I need.
Please check my last entry in the issues thread, i tested with an rpi3 and the brandnew g2core board gquintic and it works as designed. So, please check ur javascript console or try another browser. May i can help in a hangout session?
