ChiliPeppr network - I’m having trouble with my CNC stopping/starting with arc’s. I’ve played around with some of the “pre-loaded” lines and “delay per event” and can improve but not solve.
G1 representation of G2/G3 macro does not seem to modify behavior.
Is there material anywhere that someone can share that will help me root cause if its a Laptop hardware issue, JSON issue, Chilipeppr issue, or tinyg issue?
I’m not sure I’m understanding the planner/buffer status bars correctly.
The laptop using about 2+MB of RAM for Chrome during the cut and JSON is about 50-80k. (only 4MB available)
Communication will actually interrupt during arc’s and then briefly re-establish during straight motion only to be interrupted again.
Any ideas? I’m about ready to switch to Universal G Code sender just to try and split the problem.
(tinyg v8, 440.2, JSON 1.94)
