Choosing a K40 control board upgrade
Sorry one more question…
Any thoughts on which way to go for a control board upgrade? Cohesion 3D, Mini Gerbil, Cloudray, ARDUINO GRBL???
Which, in your opinion serves as the best solution for beginners from a cost/value/use perspective?
Thanks again!
Paul You should start a new thread and ask you quesiton there. But let me ask you a question. You have an extra $250 you feel like spending to be able to spend $60 more to use lightburn. and spend half an hour installing hardware? If so go for a c3d.
Paul, time is money go with the c3d unless you like bashing your head into finding pins soldering researching probably breaking and having to re order a board programming and firmware compiling and all kinds of crap.
Are you happy with your laser cutting projects? What makes you feel like the m2 board is lacking? Basically, why u think u need board upgrade?
@Paul_Chamberlain the 2-axis mini gerbil is probably the best value for an easy drop in replacement.
Thank you, Ned.
Paul
Paul M. Chamberlain
+1 202.239.0008 :us:
+34 629.926.950 :es:
