Circulair menu
I noticed that in original Ultimakers the knob for selecting files is “circular”; meaning that after the last file is seen it jumps back to the first line of the menu again.
Also when you rotate the knob counterclock wise you jumb automatically to the last line of the menu, or in case of the files in your directory of your SD card the last file.
Is there a way to implement this in the Smoothieboard + GLCD as well?
And what do I need to change to the CONFIG file to get this done?
That is not something that has been implemented, it would require adding new code to Smoothie’s source.
