CNC and 3d printing Firmware hotswap?
So I am about to convert my 3d printer to also do some milling. I thought I came across this before and they said it was possible.
So I will be making a gantry that is hot swappable with the hotend and the spindle. I will be going back and forth a bit so I was curious if it is possible to have a single firmware program set up for either or depending on what file is read? Or no?
Thanks,
Dustin
We don’t have any feature to support swapping config files.
However why would you want to ? If the gantry stays the same, you can have a single config file that supports both milling and 3D printing at the same time, there is no need for two files.
Well I read this in the documentation but the next question is where will I wire in my spindle controller? Since I already have my hotend 1 and heated bed wired. Does it matter where then? I know there are build in mosfets but I rather run the spindle of a separate controller to keep from using too much current through the board.
See the spindle section in http://smoothieware.org/cnc-mill-guide, using an external controller is actually the recommended method, and it is fully supported.
And it is no problem at all having both a hotend/bed/whatever, and a spindle, configured at the same time.
Awesome I thought I read through that enough but obviously I did not. The last thing I am a bit concerned with the g code between CNC and 3d printing g code. Will I need a CAM software that will output 3d printing g code or do I enable grbl_mode?
that’s a choice you have to make
you can’t 3D print in grbl_mode
but you can CNC mill while not in grbl_mode, it’s just a bit inconvenient ( because the “reprap” gcodes aren’t as convenient for cnc milling )
it’ll work though, we didn’t have grbl_mode until months ago, and people were milling happily without it
Okay great! Is there a reference to the difference between g codes in any githubs do you know? I assume Would be okay if everyone else was but I wouldn’t mind making sure.
We are writing the reference at the moment : http://smoothieware.org/supported-g-codes
