CNC two controllers
Hello all.
I got a 1mx1m workbee from ooznest works great.
It came with a duet 2 I have a ethernet version.
My issue is I brought a cheap 15w laser module I wanted to “bolt” on, I really wanted to use lightburn as I already use this with my k40 and it is brill.
From my understanding the duet won’t fully work with lightburn.
I have a spare C3d controller and was thinking if it was possible to run the machine with 2 controllers Duet for the mill and C3d for laser.
I wouldn’t want to combine laser and mill jobs effectively just share the X Y motors.
I don’t know if this is possible any advice would be good.
Regards Mike
The C3D board will also work as a CNC controller. You could just replace the Duet board with the C3D board and put the GRBL-LPC firmware on it which will let you run any CNC sender program as well as LightBurn.
