Community We are creating a database of information about the various K40 tool chain(s)
Community
We are creating a database of information about the various K40 tool chain(s) that we use.
Please take a few minutes and complete this survey.
I encourage you to include your G+ ID (we all know them anyway) where it asks, but of course that is optional.
The summary data from the survey will be available to the whole community.
Results are here:
Form is here:
Done.
C3D Mini for K40 bundle comes with Smoothie CNC Build. Not sure how people may interpret, may want to clarify your options.
@raykholo Done
@donkjr - If you’re interested in taking a look at Lightburn let me know - I noticed that a few people have noted that it’s their principal interface now, so if you’re curious, either myself or Ray can give you access to the beta group.
@donkjr take Jason up on his offer, I think you will be quite impressed with his software, I know I am.
@Jason_Dorie certainly. I assume it can work with any smoothie compatible board??
What type files does it import? If I could use a SU file directly I would be in heaven :)!
I currently use a VendorID / ProductID system to identify boards, but the eventual plan is to allow you to just point me at a COM port and I’ll take your word for it. For now, this allows me to detect boards without a complicated UI or protocol vetting.
Current imports are AI, PDF, EPS, with DXF and SVG in the plan. Probably PLT and HPGL as well. I’ve never dug into a SketchUp file. Is the format documented? I’m open to supporting pretty much anything as long as people will use it.
@donkjr I FB Msg’d you a link to gain group access.
@Jason_Dorie we can PM on G+ or hangouts also.
Never mind I got it thanks…
I looked for that, but didn’t see a link for it, presumably because we’re not connected. I’m less used to the G+ interface. :slight_smile:
@Jason_Dorie you have to follow me and then you can select me from a list when you post.
