Config File
I have problem in getting response from my smoothieboard. It is connecting. But not responding to all the commands.
I got my smoothieboard from a friend and it did not have a microsd in it. So I downloaded the bin file from Smoothie-edge.bin. Uploaded the firmware.bin file on the sd. loaded it onto the smoothie and usb powered it. The sd automatically flashed and the bin file turned into cur file.
I then created a config file from ConfigSamples > Smoothieboard > config. Made one change in the thermistor pin 2.7 to nc : Here is my conifg override file -> pastebin.com / Eeh1r4q8
I uploaded this file on SD card, connected to smoothie via Simplify3D and used load [file] command to override this config file.
Let me know if this is correct. Do I need to have a any external power source connected to make the smoothie run. I only have a thermistor hooked up to the board.
Ok so :
You shouldn’t worry about config override files, just normal config files, for the beginning. Remove any config-override files you have, just edit the normal config file.
You don’t need to load any config files, they are automatically loaded.
What commands is Smoothie not answering to ?
I am having trouble in getting response for M105. I have a thermistor connected to the board running on usb power. Let me know if this is right
Do you get a response to M119 ?
This is what I get for the following commands
SENT: M105
RECEIVED: ok
SENT: M114
RECEIVED: ok C: X:0.000 Y:0.000 Z:0.000 A:0.000 B:0.000 C:0.000
SENT: M119
RECEIVED:
RECEIVED: ok
SENT: M501
RECEIVED: File not found: /sd/config-override
can you give me an *exact* list of the filenames present on your sd card ?
Check the screenshot here -> i.imgur.com / RQkZpFR.jpg
You do not have a configuration file on your SD card … so it’s normal that nothing will work.
See http://smoothieware.org/configuring-smoothie
