config-get isn't finding anything
So I got a smoothieboard and am trying to set it up. Nothing was happening so I did some troubleshooting, wanted to make sure the config was correct. I have a config file on the sd card, I have edited config files, downloaded the example and put that directly on, and a few combinations and I still can’t get @config-get to return anything.
@config-get acceleration - will return “cached:acceleration is not in config”
When I put the “firm” in there I get “firm: acceleration is not in config”
When I put the “sd” in there I do not get a response.
I have tried a couple other config settings that should be in there and I get the same response.
So is this normal, or am I missing something? I have updated the firmware and am out of ideas. Any help would be appreciated.
Can you try formatting the SD card and putting in a fresh config and firmware.bin file ?
What do the LEDs on the board show ( is LED 4 on ) ?
Thanks for the idea, but didn’t work. I tried formatting the SD card a couple different formats to see if it would help, but same as above.
All the lights are on, 4 is on, 2 and 3 are blinking.
The card that came with it seemed to have gotten corrupted and wouldn’t boot, so we tried another card we had on hand a few days ago. I am going to go buy another and see if that does anything.
Don’t try different formats, only FAT32 is valid.
What does “@cat /sd/config” tell you ?
You are great. I have windows 10 and was foolishly formating it in there. It has no option for fat32. Once I formated for fat32 it worked like a charm. I can’t thank you enough, now on to cutting hopefully.
