Confused with G0 movement
Hi all,
I’ve had the smoothieboard laying on the shelve for a few years. Just got around to playing whit it and installed it in a cheap China CNC mill that (prior to fitting the smoothieboard would accept movement only via a native LPT1 port)
I’ve pretty much solved everything from the information on smoothieware.org, and / or googeling around for information. But the behavior I’m experiencing now boggles me. This is probably a minor but at the moment I cannot get my head around it:
G0 X500 will result in a movement of 50mm, instead of what I suspect 500mm. This (division by a factor 10) seems to go for all parameters given.
My Setup:
  • Board: Smoothieboard v1 3x,
  • Firmware: I could not find a version number, but installed the latest “firmware-cnc-latest.bin” 2 days ago,
  • My configuration > (sorry Im not allowed to post links) pastebin.com / FWFyLM2T
  • Prob. not relevant but I send the Gcodes via Pronterface running on Windows 10
Not sure if I left something relevant out, please let me know if I did.
[edit]
It seems that the same behavior applies to the values in my configuration file.
Ehm… this is embarrassing… my apologies… I’ve recalculated the steps per unit, and now all is fine.
This thread can be closed…
