The E3D PT100 amplifier board has three outputs connections - +ve, ground and signal.
So, I assume that ground goes to ground. +ve goes to a +3.3V supply. Signal goes to the thermistor pin and will vary between 1 and 3.3V
Is this a reasonable assumption? Any advice appreciated.
