Considering building a Delta Printer as my second printer.
Considering building a Delta Printer as my second printer. Which of the Delta printers would you receommend to build that has some good info & help. I have access to 30mm x 30mm Aluminium Extrusions. Don’t have access to the 20mm x 20mm extrutions.
Would like your opinion ? #Deltaprinter #3Dprining reprap #3Dprint
I’m really happy with Steve Graber’s cerebrus line. Designs available in the usual places.
Search on his g+ page and at http://3d.grabercars.com
I am using a spiderbot and am very happy with it. I don’t know if the design is open source…
I am using a Kossel built with 15mm extrusions. I believe there are variants for 20 and 30mm as well. It is open source.
I am getting excellent print quality from mine.
@Don_Moss , do you know where I can get hold of the 30mm printed parts from. I done a search on Google for Kossel and only found 20mm & 15mm. I like to try the Kossel.
