Corellaser question #2. Yesterday I imported a file and it cut close to its original size. Today now its cutting /engraving approximately 50%. When I import it corel is telling me that it is 1.75 inches x 2 but it not cutting /engraving to true size, I did nothing different than I did yesterday. I have similar problems when I use laser drw3 as well. Any suggestions or tips?
When you go to cut screen select properties and select what version boad[ that is on its side and has the usb dongle plugged into it] you have,mine was set to m1 something and my versikn board is m2 something so i had to change the board selection to get speed varations to work
I did change it the day before to m2 and I did check again yesterday and believe it still was on m2. Ill double check again. Is it something that needs changed once or each time before engraving?
Just once and save it i think ,been awile since i did change mime…
Did you check the model on your board? Is it Nano2 board? The model is printed on the board.
If nothing else helps, reinstall CorelLaser, I had the same problem, cutting 10x3mm instead of 10mm square, and it worked fine again after reinstalling it.
Its a M2 nano board. Im going to mess with it this morning and try to figure it out. If not I’ll ask again after lunch.
Well I tried all different settings, different file types it cuts 50% smaller than specified. It is also cutting 2 times on the cut line no matter what Ive tried. Help please
Did you reinstall the plugin? No joy?
I figured it out it was the dpi was wrong
