Could somebody help please, I’m installing LW4 on my Pi but as a novice in terminal I have hit the snag that the Github install tutorial is for LW3 so I am unsure of that I need to replace this with?
cp /home/pi/LaserWeb3/laserweb3.service /etc/systemd/system/laserweb3.service
sudo systemctl enable laserweb3.service
sudo systemctl start laserweb3
Is it as simple as changing Laserweb3 to 4 or is it more involved.
Thanks for your time.
Ignore the misleading title of the link. It guides you directly to rhe install instructions fo LW4 on raspi
@Tinkering_On_Steroid Thank you obviously I’m so last month when it was called Laserweb4 lol
+Peter van der Walt is that the same install process then? I’m just trying not have to keep connecting my mac up to my k40 as it’s in my workshop. I would rather just plug in the Pi and mount it inside the cabinet so i can access it from any pc should I need to.
I’ve managed to get it all connected thank you, My main goal is to utilise the pi’s that I have and run my 3d printer and k40 from these in the workshop so I can have a dedicated station for a pc/Mac in the corner out the way. I will see how this goes for now but if I run into problems I will have to re think it.Thanks once again.
