Could somebody please help me. I’m trying to setup around 15 meters of apa102 LEDs. I have the t1000s controller. I also have a 350 power supply. How do I wire everything?
That has nothing to do with the FastLED library…
Read-up on the T1000S controller datasheets for the info you want…
The FastLED library is for custom-programming Arduino (and similar) microcontrollers to do custom animations and reactive patterns. The T1000S is a different animal altogether: it just plays back pre-stored LED patterns from an SD card; no programming involved per se.
JP is right: the T1000S data sheets should be able to help you out here.
And if you decide you want to get into custom coding to program your own animations, the FastLED library can help!
Thanks.
Does anyone here sell already programmed Arduinos. With many patterns on it. I have lights around a business and I need patterns.
