Could someone explain the timebase and phase offset variables in beatsin8(): LIB8STATIC uint8_t beatsin8( accum88 beats_per_minute, uint8_t lowest = 0, uint8_t highest = 255,
uint32_t timebase = 0, uint8_t phase_offset = 0)
I am trying to trigger a light at a specific point, but I want it to start at lowest brightness. I was hoping that resetting the timer through:
#define USE_GET_MILLISECOND_TIMER 1
and
uint32_t get_millisecond_timer()
return millis() - resetTime;
would do the trick but it seems to reset to the top of the sine curve (full brightness), not the bottom (low brightness) which is what I’m looking for.
