Could someone help me with a box design. I need it to have a removable lid and two compartments
I use online make a box link http://makeabox.io/ and http://www.makercase.com/ there are a couple more
@Phillip_Conroy Question, how do you handle the PDF files that these sites generated. I can’t figure out how to get them into coreldraw.
@Nedman and how do you edit them to make more slots
@3D_Laser Lol you’re asking me? I’m still trying to figure out how to get them into Corel.
Sorry I just hit reply not thinking haha
@3D_Laser @Nedman To get a PDF into CorelDraw, use the import function. You will then be able to edit them. I do that all the time with the box maker apps. If I do not want tabs at one end, I just delete them and draw a new line. Also you will need to “select all” and make the lines thinner or else it will double cut.
@HalfNormal Everytime I try and import a PDF into CorelDraw it keeps telling me it’s a corrupt file.
@Nedman What version of CD are you using? I am using X7.
I’m using 12 which is probably the problem.
Try downloading Yuusuf’s X5 version.
Copy and paste also works if i remember correctly,with the line i just flood fill the object
@HalfNormal Thanks. I found Yuusuf’s dropbox files and installed CD X5. Importing pdf files works fine now
@Nedman I am glad you I was able to help.
