Covering wires on wearables.
With Halloween and the inevitable lit costumes approaching, here’s a quick and simple method I have for covering colored wires, or keeping multiple wires together.
Get hold of the thicker, round boot laces in the color of your choice. I prefer black since most of my stuff is worn in the dark. If you cut off the ends, you’ll find a core that slides out and leaves the woven exterior layer behind. I just cut the lace “tube” to length and slip it over the wires for a flexible, professional-looking cover.
You can also give the ends of the tube a quick drop of super glue to prevent unraveling or, if it’s a synthetic material, sometimes cutting it with a soldering gun blade does the job.
