Crazy idea time:
I plan to have a heated build chamber, but I got an idea.
Instead of using a stand alone temperature controller, could I use replicape and a thermistor located in the printer hooked up to extruder 2/heater h, plus a fan for circulating the air, and control the linked heating element and expect it to work?
At 24v and 20A I want to believe replicape can handle an output of 480w through heater h, but I am not sure I could just wire this heater directly as it says it is a 500W. Is that 20 watts going to trip the fuse - or - I could I just use a relay?
I have a 50A 24v power supply so I got some power to play with. My heated bed is 450W (18A), so I would certainly be using all the power supply can handle with everything pulling a draw, but once up to temp it shouldn’t be too bad.
Anyways, trying to avoid more controllers, and waiting for the Reach Rev B to allow for more extruders!
Thoughts?
