Curious, if I know that the drivers and LEDs are correctly setup as RGB
Curious, if I know that the drivers and LEDs are correctly setup as RGB (so that I don’t need to tell FastSPI to fix the order for me), and I find out the data that I have is in a different order, say BGR, can I purposely tell FastSPI to change the order when the controller is defined so I can send the data as is without needing to rearrange it before sending it out to the strip?
Sure - it just changes what order the bytes are sent out in - you can make it any order you want :slight_smile: In the meantime, I might also suggest punching your data provider for not giving you data in RGB ordering :slight_smile:
Sure, that would be whatever Microsoft programmer that created the BMP format. :slight_smile:
Hrm, after some fumbling last night, I decided to push the BMP format to a next revision. I’m too far into this revision to still be making changes. If I keep doing this, I’ll never release anything … so, code and hardware freeze has been implemented. Done!
