Current control problem
Suddenly discovered, that I can not change the current for the steppers on my smoothie X5 board.
If I try to change the direction (by putting “!”) - works just fine.
Any thoughts what happened? 1 month ago worked fine.
Regards.
Can you try formating your SD card, and using the latest firmware and config file from the website ( backup your current config first ) ?
Hi,
Had latest. Not working.
Than moved to original that came with the board - same story.
But if I can change the direction looks like the board can read the SD card with no issue?
Regards.
Just formatted the card. Same thing. Any suggestions? Regards.
