Cut2d with Printrun
Hi
Does Printrun (from Pronterface) work with Cut2d? I am used to making gcode with Cut2d and would like to know, if Printrun can use gcode from Cut2d.
When I load gcode from cut2d, it does not appear correctly in Printrun. Cut2d can export gcode in many “flavours” and I wonder if there are any users who know how to make cut2d make a gcode that printrun can read correctly.
Best regards,
Gustav
Pronterface has problems with non-Reprap G-code.
One solution to that, is to “upload” the file to the SD card using pronterface, then playing it from there.
Another solution is using the Smoothie web interface, or some other host.
Hi Arthur,
Thanks for taking the time to answer my newcomer question. Unfortunately I am very new to G-code (and CNC in general) so I don’t know anything about ‘non-reprap’ G-code.
I solved the problem with trail and error. When cut2d export as “Centroid CNC7” it works: The pre-view in pronterface looks correct and smoothieboard moves my CNC the correct distances.
