We don’t have any such documentation, users who own a panel just explore the tree and discover it themselves traditionally.
What are you looking for exactly ?
… what is MPG mode: it doesn’t seem to do anything
… what is the “Park Position” and what is the “Set Park Position” supposed to do. I selected the “Park Position” and it drove the head hard to the lower right and would not release until I powered it off. I was surprised it did not blow the drive or stepper.
If there is no documentation I guess I will just keep “hacking and asking” … but that may be annoying. I will however document what I find…
@Wolfmanjm X0,Y0 is not the lower right is it? I thought it was lower left?
So then how do you use the “Set Park Position” item, it doesn’t allow an entry or anything when you select it.
Is it supposed to execute a G28.1 and store the current position?
Sorry but I am still learning G-code.
yes as per the linuxcnc docs it sets the current position to the park position. fwiw most CNC people know what park is especially those using or having used linuxcnc
0,0 is usually lower left or front left, but it depends on how you set up homing. if you did not home then 0,0 is wherever the head was on power up (not a good thing)
@Wolfmanjm I home in the upper left. I thought I homed the machine and then “Set Park Position” but it still went to the lower right. I guess I will test it again.
BTW is there a motor release function other than from the panel or just powering off the machine for times when I am testing…
