@Daniel_Noree Do you use any washers in the diffs under the small beveled gears attached with screws? I have some play there even after tightening the screws - is this expected?
@Szymon_Kobalczyk No, i have no washers. Those parts need to be perfectly aligned without any play.
@Szymon_Kobalczyk I think washers might be a good idea to try later on. As wrecked a couple of diffs now I can say that its always the “output” shaft that fails where it connects to the diff case.I’ve never had any of the gears brake…
