Debugging JSON server disconnecting. I am running Ubuntu with all the software updated. Randomly, the JSON server disconnects around 2hr into a job. I have routed the serial cable away from the the spindle and I am using the best shielded serial cable I can.
Only time I’ve experienced websocket disconnects is if i’m overwhelming the browser and it drops the websocket. When I reconnect to SPJS, the serial port is still connected. So where are you seeing the disconnect? On websocket from browser to SPJS? Or from SPJS to serial port?
@jlauer I don’t have that open while I am running. I will leave it open next time. The computer is slow with lots of memory and a good graphics card but I can’t run the visual action module.
