# Robot module configurations : general handling of movement G-codes and slicing into moves
default_feed_rate 4000 # Default rate ( mm/minute ) for G1/G2/G3 moves
default_seek_rate 15000 # Default rate ( mm/minute ) for G0 moves
mm_per_arc_segment 0.5 # Arcs are cut into segments ( lines ), this is the length for these segments. Smaller values mean more resolution, higher values mean faster computation
mm_per_line_segment 1 # Lines can be cut into segments ( not usefull with cartesian coordinates robots ).
currentcontrol_module_enable true
Arm solution configuration : Cartesian robot. Translates mm positions into stepper positions
alpha_steps_per_mm 320 # Steps per mm for alpha stepper
beta_steps_per_mm 320 # Steps per mm for beta stepper
gamma_steps_per_mm 1600 # Steps per mm for gamma stepper
Planner module configuration : Look-ahead and acceleration configuration
planner_queue_size 32 # DO NOT CHANGE THIS UNLESS YOU KNOW EXACTLY WHAT YOUR ARE DOING
acceleration 1000 # Acceleration in mm/second/second.
z_acceleration 100 # Acceleration for Z only moves in mm/s^2, 0 disables it, disabled by default. DO NOT SET ON A DELTA
junction_deviation 0.05 # Similar to the old “max_jerk”, in millimeters
Stepper module configuration
microseconds_per_step_pulse 2.0 # Duration of step pulses to stepper drivers, in microseconds
base_stepping_frequency 100000 # Base frequency for stepping
Stepper module pins ( ports, and pin numbers, appending “!” to the number will invert a pin )
alpha_step_pin 2.0 # Pin for alpha stepper step signal
alpha_dir_pin 0.5 # Pin for alpha stepper direction
alpha_en_pin 0.4 # Pin for alpha enable pin
alpha_current 1.9 # X stepper motor current
x_axis_max_speed 10000 # mm/min
alpha_max_rate 10000 # mm/min actuator max speed
beta_step_pin 2.1 # Pin for beta stepper step signal
beta_dir_pin 0.11 # Pin for beta stepper direction
beta_en_pin 0.10 # Pin for beta enable
beta_current 1.9 # Y stepper motor current
y_axis_max_speed 10000 # mm/min
beta_max_rate 10000 # mm/min actuator max speed
gamma_step_pin 2.2 # Pin for gamma stepper step signal
gamma_dir_pin 0.20 # Pin for gamma stepper direction
gamma_en_pin 0.19 # Pin for gamma enable
gamma_current 2.0 # Z stepper motor current
z_axis_max_speed 600 # mm/min
gamma_max_rate 600 # mm/min actuator max speed
Serial communications configuration ( baud rate default to 9600 if undefined )
#uart0.baud_rate 115200 # Baud rate for the default hardware serial port
#second_usb_serial_enable true # This enables a second usb serial port (to have both pronterface and a terminal connected)
#msd_disable false # disable the MSD (USB SDCARD) when set to true
#leds_disable true # disable using leds after config loaded
#dfu_enable false # for linux developers, set to true to enable DFU
#watchdog_timeout 10 # watchdog timeout in seconds, default is 10, set to 0 to disable the watchdog
Extruder module configuration
extruder.hotend1.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend1.steps_per_mm 850 # Steps per mm for extruder stepper
extruder.hotend1.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend1.acceleration 200 # Acceleration for the stepper motor mm/sec²
extruder.hotend1.max_speed 150 # mm/s
extruder.hotend1.step_pin 2.3 # Pin for extruder step signal
extruder.hotend1.dir_pin 0.22 # Pin for extruder dir signal
extruder.hotend1.en_pin 0.21 # Pin for extruder enable signal
delta_current 0.6 # Extruder stepper motor current
extruder.hotend2.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend2.steps_per_mm 850 # Steps per mm for extruder stepper
extruder.hotend2.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend2.acceleration 200 # Acceleration for the stepper motor mm/sec²
extruder.hotend2.max_speed 150 # mm/s
extruder.hotend2.step_pin 2.8
extruder.hotend2.dir_pin 2.13
extruder.hotend2.en_pin 4.29
epsilon_current 0.6 # Extruder stepper motor current
Laser module configuration
laser_module_enable false # Whether to activate the laser module at all. All configuration is
# ignored if false
Hotend temperature control configuration
temperature_control.hotend1.enable true # Whether to activate this ( “hotend” ) module at all. All configuration is ignored if false.
temperature_control.hotend1.thermistor_pin 0.23 # Pin for the thermistor to read
temperature_control.hotend1.heater_pin 2.7 # Pin that controls the heater
temperature_control.hotend1.thermistor Semitec #
#temperature_control.hotend1.beta 4480 # or set the beta value
temperature_control.hotend1.set_m_code 104 #
temperature_control.hotend1.set_and_wait_m_code 109 #
temperature_control.hotend1.designator T0 #
temperature_control.hotend1.pwm_frequency 250 #How many times per second to switch the heating element on or off. Set to a low value ( 20 ) if using a Solid State Relay.
temperature_control.hotend1.max_temp 320 # Set maximum temperature
temperature_control.hotend1.min_temp 0 # Set minimum temperature
temperature_control.hotend1.runaway_range 60 #
#temperature_control.hotend1.runaway_heating_timeout 130 #
temperature_control.hotend1.p_factor 48.0 #
temperature_control.hotend1.i_factor 3.753 #
temperature_control.hotend1.d_factor 154 #
temperature_control.hotend2.enable true # Whether to activate this ( “hotend” ) module at all. All configuration is ignored if false.
temperature_control.hotend2.thermistor_pin 0.23 # Pin for the thermistor to read
temperature_control.hotend2.heater_pin 2.7 # Pin that controls the heater
temperature_control.hotend2.thermistor Semitec #
#temperature_control.hotend2.beta 4480 # or set the beta value
temperature_control.hotend2.set_m_code 104 #
temperature_control.hotend2.set_and_wait_m_code 109 #
temperature_control.hotend2.designator T1 #
temperature_control.hotend2.pwm_frequency 250 #How many times per second to switch the heating element on or off. Set to a low value ( 20 ) if using a Solid State Relay.
temperature_control.hotend2.max_temp 320 # Set maximum temperature
temperature_control.hotend2.min_temp 0 # Set minimum temperature
temperature_control.hotend2.runaway_range 60 #
#temperature_control.hotend2.runaway_heating_timeout 130 #
temperature_control.hotend2.p_factor 48.0 #
temperature_control.hotend2.i_factor 3.753 #
temperature_control.hotend2.d_factor 154 #
temperature_control.bed.enable true #
temperature_control.bed.thermistor_pin 0.24 #
temperature_control.bed.heater_pin 2.5 #
#temperature_control.bed.thermistor EPCOS100K #
temperature_control.bed.beta 4480 # or set the beta value
temperature_control.bed.set_m_code 140 #
temperature_control.bed.set_and_wait_m_code 190 #
temperature_control.bed.designator B #
temperature_control.bed.runaway_range 25 #
temperature_control.bed.pwm_frequency 5 #
temperature_control.bed.p_factor 53.4 #
temperature_control.bed.i_factor 0.803 #
temperature_control.bed.d_factor 886 #
Switch module for fan control
switch.fan.enable true #
switch.fan.input_on_command M106 #
switch.fan.input_off_command M107 #
switch.fan.output_pin 2.4 #
switch.fan.output_type pwm # pwm output settable with S parameter in the input_on_comand
switch.fan.pwm_period_ms 50 #
switch.misc.enable false #
switch.misc.input_on_command M42 #
switch.misc.input_off_command M43 #
switch.misc.output_pin 0.26 #
Endstops
endstops_enable true # the endstop module is enabled by default and can be disabled here
#corexy_homing false # set to true if homing on a hbit or corexy
alpha_min_endstop 1.24^ # add a ! to invert if endstop is NO connected to ground
#alpha_max_endstop 1.25^ #
alpha_homing_direction home_to_min # or set to home_to_max and set alpha_max
alpha_min -152 # this gets loaded after homing when home_to_min is set
alpha_max 300 # this gets loaded after homing when home_to_max is set
beta_min_endstop 1.26^ #
#beta_max_endstop 1.27^ #
beta_homing_direction home_to_min #
beta_min -152 #
beta_max 300 #
gamma_min_endstop 1.28^ #
#gamma_max_endstop 1.29v! #
gamma_homing_direction home_to_min #
gamma_min 0 #
gamma_max 180 #
optional enable limit switches, actions will stop if any enabled limit switch is triggered
#alpha_limit_enable false # set to true to enable X min and max limit switches
#beta_limit_enable false # set to true to enable Y min and max limit switches
#gamma_limit_enable false # set to true to enable Z min and max limit switches
#move_to_origin_after_home false # move XY to 0,0 after homing
#probe endstop
#probe_pin 1.29 # optional pin for probe
alpha_fast_homing_rate_mm_s 50 # feedrates in mm/second
beta_fast_homing_rate_mm_s 50 # "
gamma_fast_homing_rate_mm_s 20 # "
alpha_slow_homing_rate_mm_s 25 # "
beta_slow_homing_rate_mm_s 25 # "
gamma_slow_homing_rate_mm_s 6 # "
alpha_homing_retract_mm 5 # distance in mm
beta_homing_retract_mm 5 # "
gamma_homing_retract_mm 4 # "
#endstop_debounce_count 100 # uncomment if you get noise on your endstops, default is 100
Switch module for servo control
switch.servo.enable true #
switch.servo.input_on_command M280 # M280 S7.5 would be midway
switch.servo.input_off_command M281 # same as M280 S0 0% duty cycle, effectively off
switch.servo.output_pin 1.23 # must be a PWM capable pin
switch.servo.output_type hwpwm # H/W pwm output settable with S parameter in the input_on_comand
switch.servo.pwm_period_ms 20 # set period to 20ms (50Hz) default is 50Hz
optional Z probe
zprobe.enable true # set to true to enable a zprobe
zprobe.probe_pin 1.28^ # pin probe is attached to if NC remove the !
zprobe.slow_feedrate 6 # mm/sec probe feed rate
#zprobe.debounce_ms 1 # set if noisy
zprobe.fast_feedrate 190 # move feedrate mm/sec
zprobe.probe_height 3 # how much above bed to start probe
associated with zprobe the leveling strategy to use
leveling-strategy.delta-grid.enable true
leveling-strategy.delta-grid.radius 115
leveling-strategy.delta-grid.is_square true
leveling-strategy.delta-grid.do_home false
leveling-strategy.delta-grid.size 11
leveling-strategy.delta-grid.max_x 150
leveling-strategy.delta-grid.max_y 100
leveling-strategy.delta-grid.probe_offsets 0,-43,0 # probe offsets x,y,z (Z should always be 0)
leveling-strategy.delta-grid.save true
leveling-strategy.delta-grid.initial_height 5
save_g92 true
kill button (used to be called pause) maybe assigned to a different pin, set to the onboard pin by default
kill_button_enable true # set to true to enable a kill button
kill_button_pin 2.12 # kill button pin. default is same as pause button 2.12 (2.11 is another good choice)
panel.enable true # set to true to enable the panel code
panel.lcd reprap_discount_glcd #
panel.spi_channel 0 # spi channel to use ; GLCD EXP1 Pins 3,5 (MOSI, SCLK)
panel.spi_cs_pin 0.16 # spi chip select ; GLCD EXP1 Pin 4
panel.encoder_a_pin 3.26^ # encoder pin ; GLCD EXP2 Pin 3
panel.encoder_b_pin 3.25^ # encoder pin ; GLCD EXP2 Pin 5
panel.click_button_pin 1.30!^ # click button ; GLCD EXP1 Pin 2
panel.buzz_pin 1.31 # pin for buzzer ; GLCD EXP1 Pin 1
#panel.back_button_pin 2.11!^ # back button ; GLCD EXP2 Pin 8
panel.encoder_resolution 100 # the number of pulses the encoder emits per detent/click
kill_button_pin 2.11 # kill button pin. default is same as pause button 2.12 (Add ^ for external buttons)
panel.menu_offset 0 # some panels will need 1 here
panel.gamma_jog_feedrate 200 # z jogging feedrate in mm/min
panel.hotend_temperature 185 # temp to set hotend when preheat is selected
panel.bed_temperature 60 # temp to set bed when preheat is selected
turn the PSU off when the hotend temp cools below 50, only do this once M1100 S1 has been executed to arm it
temperatureswitch.psu_off.enable true #
temperatureswitch.psu_off.designator T # first character of the temperature control designator to use as the temperature sensor to monitor
temperatureswitch.psu_off.switch psu # select which switch to use, matches the name of the defined switch
temperatureswitch.psu_off.threshold_temp 50.0 # temperature to trigger at when falling
temperatureswitch.psu_off.heatup_poll 30 # poll heatup every 30 seconds
temperatureswitch.psu_off.cooldown_poll 30 # poll cooldown every 30 seconds
temperatureswitch.psu_off.arm_mcode 1100 # M1100 S1 will arm it
temperatureswitch.psu_off.trigger falling # only trigger when the temp falls below after being above
temperatureswitch.psu_off.inverted false # turn the switch off when we trigger (by default switches on when rising and off when falling)
switch.psu.enable true # turn atx on/off
switch.psu.input_on_command M81 #
switch.psu.input_off_command M80 #
switch.psu.output_pin 1.22 #
switch.psu.output_type digital # on/off only
switch.psu.fail_safe_set_to 1 # so the ATX turns off on a system crash
#switch.psu.ignore_on_halt false # so the ATX does not turn off on a HALT condition (like limit trigger)
# However leave commented or set to false if you want the ATX to turn off for an over heat fault condition
