Did a forcerefresh=true on my grblLaser workspace today. Now my serial port console is inundated with ~. @Jarret_Luft am I missing a settings somewhere?
I am seeing it in both grbl and grblLaser. John upgraded the json server and the corresponding serial port widget recently.
Yeah, I wonder if it’s anything from my upgrades, but those were done on Monday. You would have seen it then. How does the TinyG workspace function for you?
I need to get to the local makerspace and print that mounting bracket so I can use my tinyg.
When I load up the workspace, I see the buttons in your grbl widget appear briefly before disappearing. I recalled having to click on Realtime Status before this behavior happens. Perhaps somehow Realtime status is on by default now? The symptoms suggest such is the case since the serial console widget shows continuous stream of ~ symbols.
I am using spjs v1.7. The widget will not let me connect with an older server.
