On the BOM it notes one of each part. I’m thinking there should be more than one, any suggestions on how many plugs I should order? I can extrapolate the number of pins from that.
Thnx
(Azteeg ordered, Misumi ordered, Printed parts on their way… Now just need to order the other components)
I find the micro molex connectors a bit of a pain to deal with, you might consider using something else. The number of pins depends on the carriage/hotend combo you’re planning to use (heater, hotend fan, blower, led lights, …)
@Oliver_Seiler thanks Oliver, just trying to sort out where I should be using molex connectors. I’ve no idea where I should be putting them. It looks like there is a molex connector on the hot end carriage but not sure where else they are needed? Stepper wires? Heater cartridge? Thermistor?
You need at least 6: 2x Heater, 2x Thermistor, 2x Fan(s). If you add leds, separate command for hot end fan and blower fan it may change.
Order some spare pins, you’ll probably break some (and it’s cheap).
I’d highly recommend not putting all cables on the same connector, because it prevents you from ever moving on to another carriage with different cable needs without re-wiring the connector (which is a massive pain). It also makes it a lot easier to swap out a part for a replacement e.g. if you have a second heater block.
E.g. a 2 pin for the cooling fan, 4 pin for heater + thermistor, 2 for the blower and 2 for LED if required.
@Daniel_F how long did they take to come? They are certainly cheap enough. The molex from Digikey are bulkier which may not be a positive if I use a few in that same area.
