Digital laser power settings.
My K40 has the digital control board with three digit seven segment LEDs like others I have seen posted here, the power supply is the kind without an external current limiting power resistor.
I made a table of digital power setting and laser current measured by ammeter in the laser negative lead. Here are the results plotted as a graph. I do not now run the machine at greater then 75 on the digital setting, approx 18 mA. The laser strikes at just below 10, approx 3mA. I measured the current with both a digital multi-meter and moving coil ammeters.
Different setups could well produce different currents, I don’t know and I have nothing to compare against. I’m thinking of making an EHT voltage probe to see what voltage the tube is running at, I’ve seen an example on the net using a chain of high value resistors. hth David.
