Digital RGB Led Strip controled by arduino pro mini + bluetooth module Using fill_rainbow()
Using fill_rainbow() to sync leds colors with razer rgb wallpaper (monitor).
Are you using a processing sketch to the arduino?
Not exactly. The synchronization between wallpaper and led strip is manual and works only in this case. To make a real ambilight, you’ll need a software running on your computer to take a screenshot (like Processing or Bambilight) and check the color of each pixel individually.
Tommy Sciano. I did not understand your question about processing application, sorry…
