Does anyone has the firmware link for download?
I have one on dropbox but download failure as the file too big.
Are you still needing the file? If so, let me know and I will post for you.
Yes, thanks Michael Coley! I need it and dropbox doesn’t work as I didn’t buy for more space, it only 2GB storage. That’s perfect if you have the file for me to dowload. Thanks a lot.
Here is the link to Ares website: http://easyarts3d.com/forum/viewtopic.php?f=19&t=341
I will also link the files directly. There are two different firmwares available. One for 220 rods and one for 230 rods.
http://www.filedropper.com/aresfirmware3variants
I archived all three together. I forgot there was a 215 as well. Hope this helps.
Thanks Michael.
Do you have Octopil img file?
the one I need is 14.8GB, which is raspberrypi image file. That’s perfect if you also have this one.
I’m not at home right now. If I don’t have it I will get it from the Easyarts forum. Do you not have access to the forum? If you do, you will be able to find it faster than I will be able to post today.
On a side note, I switched from the stock Ares octopi build and used the currently available octopi. No issues whatsoever. Updates regularly without issues too. Just install the correct firmware for your post length.
I visited Easyarts and tried to download it but the link doesn’t work anymore. My printer always got errors, it shows “echo: SD card…” and “…firmware error” Everytime I rewrite SD card, it works a while, but my original file seems damaged due to my harddisk(maybe). So, I want to try to re-download the file again. Let’s see it would be better or not. Thanks Michael!
I’m loading the file to my dropbox now. Should have a link up for you in about an hour.
Thanks Michael, will wait for your link.
Says my drop box is out of space. I will try to get this for you today. Sorry!
I don’t know what is going on. Let me try again. Here is the link:
Seems to be working now. Maybe I tried to link it too fast. Good luck!
Thanks Michael. I am trying to download the file.
OK. Let me know how it goes.
I downloaded and installed, but the problem is still there.
