Does anyone have a diagram for wiring the motors on the tiny g?
Hey @Austen_Greene it will be a little more simple than it first appears. All those wires can be intimidating.
Wire X to motor 1
Y to 2
Y to 3
Z to 4
Grab a motor, not connected to the machine, twist any two wires together.
Turn the motor shaft.
Undo the two twisted wires.
Turn the motor.
If it is less resistance to turning you have a motor pair.
If not, try a different wire pair.
At one point a pair of wires twisted together will make the motor harder to turn. Plug these into A- and A+. Plug the other two into B- and B+. Done.
If the motor turns the opposite direction as intended in the end, switch the two As OR the two Bs.
OK, that was the problem I am having with opposite turning. I found the pairs and wired them just as the manual said but all my motors go the opposite direction. My Z axis for instance, plunges where it should be lifted and lifts when it should be plunging to cut if that makes any sense.
Additionally, I have been having issues dragging gcode files into CP. Sometimes it says that the project cache is full and then the browser crashes. Does it with both chrome and firefox. Any thoughts?
Chrome- in Chilipeppr, go to the upper LH widget window. Click the folder button. Erase all previous jobs. Keep this folder empty when you can.
Reversing directions. You can go to the TinyG widget on the RH middle window and click the settings button. One window will have "normal"in it. Switch this to opposite (I believe is what it says)… This is the same as reversing one pair of stepper wires.
So I got everything working except the X axis. For whatever reason I don’t think the TinyG is communicating movement to Motor 1. When I jog the Y or Z axis there are 2 red light that flash and then green lights that light up on the board but for X the green lights don’t illuminate. Not sure if the socket on the board is bad or if something else is going on. Do you have any ideas? I have all the settings set the same as the others but Im getting nothing.
@Austen_Greene post us your TinyG dump.
I’m at work right now but I will when I get home. How do I get to the dump?
I haven’t figured out how to find the dump yet but I think for some reason the x motor is tied into the y motors even though they are wired separate and are identified correctly in TinyG I noticed the motor light for X on when I jog the Y axis so I went over and touched the coupling as i moved Y and could feel X motor energize. I have no clue what is going on. Any help would be greatly appreciated.
Go to the serial port in CP(Chilipeppr), lower LH corner.
Type $$ in the window.
Copy everything below the $$.
[fb] firmware build 440.20 [fv] firmware version 0.97 [hp] hardware platform 1.00 [hv] hardware version 8.00 [id] TinyG ID 3Y2462-UDF [ja] junction acceleration 100000 mm [ct] chordal tolerance 0.0100 mm [sl] soft limit enable 0 [st] switch type 0 [0=NO,1=NC] [mt] motor idle timeout 2.00 Sec [ej] enable json mode 0 [0=text,1=JSON] [jv] json verbosity 4 [0=silent,1=footer,2=messages,3=configs,4=linenum,5=verbose] [js] json serialize style 1 [0=relaxed,1=strict] [tv] text verbosity 1 [0=silent,1=verbose] [qv] queue report verbosity 1 [0=off,1=single,2=triple] [sv] status report verbosity 1 [0=off,1=filtered,2=verbose] [si] status interval 250 ms [ec] expand LF to CRLF on TX 0 [0=off,1=on] [ee] enable echo 0 [0=off,1=on] [ex] enable flow control 1 [0=off,1=XON/XOFF, 2=RTS/CTS] [baud] USB baud rate 5 [1=9600,2=19200,3=38400,4=57600,5=115200,6=230400] [net] network mode 0 [0=master] [gpl] default gcode plane 0 [0=G17,1=G18,2=G19] [gun] default gcode units mode 1 [0=G20,1=G21] [gco] default gcode coord system 1 [1-6 (G54-G59)] [gpa] default gcode path control 2 [0=G61,1=G61.1,2=G64] [gdi] default gcode distance mode 0 [0=G90,1=G91] [1ma] m1 map to axis 0 [0=X,1=Y,2=Z…] [1sa] m1 step angle 1.800 deg [1tr] m1 travel per revolution 8.0000 mm [1mi] m1 microsteps 8 [1,2,4,8] [1po] m1 polarity 0 [0=normal,1=reverse] [1pm] m1 power management 2 [0=disabled,1=always on,2=in cycle,3=when moving] [2ma] m2 map to axis 1 [0=X,1=Y,2=Z…] [2sa] m2 step angle 1.800 deg [2tr] m2 travel per revolution 8.0000 mm [2mi] m2 microsteps 8 [1,2,4,8] [2po] m2 polarity 0 [0=normal,1=reverse] [2pm] m2 power management 2 [0=disabled,1=always on,2=in cycle,3=when moving] [3ma] m3 map to axis 1 [0=X,1=Y,2=Z…] [3sa] m3 step angle 1.800 deg [3tr] m3 travel per revolution 8.0000 mm [3mi] m3 microsteps 8 [1,2,4,8] [3po] m3 polarity 0 [0=normal,1=reverse] [3pm] m3 power management 2 [0=disabled,1=always on,2=in cycle,3=when moving] [4ma] m4 map to axis 2 [0=X,1=Y,2=Z…] [4sa] m4 step angle 1.800 deg [4tr] m4 travel per revolution 8.0000 mm [4mi] m4 microsteps 8 [1,2,4,8] [4po] m4 polarity 1 [0=normal,1=reverse] [4pm] m4 power management 2 [0=disabled,1=always on,2=in cycle,3=when moving] [xam] x axis mode 1 [standard] [xvm] x velocity maximum 800 mm/min [xfr] x feedrate maximum 800 mm/min [xtn] x travel minimum 0.000 mm [xtm] x travel maximum 150.000 mm [xjm] x jerk maximum 20 mm/min^3 * 1 million [xjh] x jerk homing 40 mm/min^3 * 1 million [xjd] x junction deviation 0.0500 mm (larger is faster) [xsn] x switch min 0 [0=off,1=homing,2=limit,3=limit+homing] [xsx] x switch max 0 [0=off,1=homing,2=limit,3=limit+homing] [xsv] x search velocity 500 mm/min [xlv] x latch velocity 100 mm/min [xlb] x latch backoff 5.000 mm [xzb] x zero backoff 1.000 mm [yam] y axis mode 1 [standard] [yvm] y velocity maximum 800 mm/min [yfr] y feedrate maximum 800 mm/min [ytn] y travel minimum 0.000 mm [ytm] y travel maximum 150.000 mm [yjm] y jerk maximum 20 mm/min^3 * 1 million [yjh] y jerk homing 40 mm/min^3 * 1 million [yjd] y junction deviation 0.0500 mm (larger is faster) [ysn] y switch min 0 [0=off,1=homing,2=limit,3=limit+homing] [ysx] y switch max 0 [0=off,1=homing,2=limit,3=limit+homing] [ysv] y search velocity 500 mm/min [ylv] y latch velocity 100 mm/min [ylb] y latch backoff 5.000 mm [yzb] y zero backoff 1.000 mm [zam] z axis mode 1 [standard] [zvm] z velocity maximum 800 mm/min [zfr] z feedrate maximum 800 mm/min [ztn] z travel minimum 0.000 mm [ztm] z travel maximum 150.000 mm [zjm] z jerk maximum 20 mm/min^3 * 1 million [zjh] z jerk homing 40 mm/min^3 * 1 million [zjd] z junction deviation 0.0500 mm (larger is faster) [zsn] z switch min 0 [0=off,1=homing,2=limit,3=limit+homing] [zsx] z switch max 0 [0=off,1=homing,2=limit,3=limit+homing] [zsv] z search velocity 400 mm/min [zlv] z latch velocity 100 mm/min [zlb] z latch backoff 5.000 mm [zzb] z zero backoff 1.000 mm [aam] a axis mode 0 [disabled] [avm] a velocity maximum 230400 deg/min [afr] a feedrate maximum 230400 deg/min [atn] a travel minimum -1.000 deg [atm] a travel maximum -1.000 deg [ajm] a jerk maximum 5760 deg/min^3 * 1 million [ajh] a jerk homing 11520 deg/min^3 * 1 million [ajd] a junction deviation 0.0500 deg (larger is faster) [ara] a radius value 0.1990 deg [asn] a switch min 1 [0=off,1=homing,2=limit,3=limit+homing] [asx] a switch max 0 [0=off,1=homing,2=limit,3=limit+homing] [asv] a search velocity 600 deg/min [alv] a latch velocity 100 deg/min [alb] a latch backoff 5.000 deg [azb] a zero backoff 2.000 deg [bam] b axis mode 0 [disabled] [bvm] b velocity maximum 3600 deg/min [bfr] b feedrate maximum 3600 deg/min [btn] b travel minimum -1.000 deg [btm] b travel maximum -1.000 deg [bjm] b jerk maximum 20 deg/min^3 * 1 million [bjd] b junction deviation 0.0500 deg (larger is faster) [bra] b radius value 1.0000 deg [cam] c axis mode 0 [disabled] [cvm] c velocity maximum 3600 deg/min [cfr] c feedrate maximum 3600 deg/min [ctn] c travel minimum -1.000 deg [ctm] c travel maximum -1.000 deg [cjm] c jerk maximum 20 deg/min^3 * 1 million [cjd] c junction deviation 0.0500 deg (larger is faster) [cra] c radius value 1.0000 deg [p1frq] pwm frequency 100 Hz [p1csl] pwm cw speed lo 1000 RPM [p1csh] pwm cw speed hi 2000 RPM [p1cpl] pwm cw phase lo 0.125 [0…1] [p1cph] pwm cw phase hi 0.200 [0…1] [p1wsl] pwm ccw speed lo 1000 RPM [p1wsh] pwm ccw speed hi 2000 RPM [p1wpl] pwm ccw phase lo 0.125 [0…1] [p1wph] pwm ccw phase hi 0.200 [0…1] [p1pof] pwm phase off 0.100 [0…1] [g54x] g54 x offset -3.000 mm [g54y] g54 y offset -34.816 mm [g54z] g54 z offset 4.970 mm [g54a] g54 a offset 0.000 deg [g54b] g54 b offset 0.000 deg [g54c] g54 c offset 0.000 deg [g55x] g55 x offset 75.000 mm [g55y] g55 y offset 75.000 mm [g55z] g55 z offset 0.000 mm [g55a] g55 a offset 0.000 deg [g55b] g55 b offset 0.000 deg [g55c] g55 c offset 0.000 deg [g56x] g56 x offset 0.000 mm [g56y] g56 y offset 0.000 mm [g56z] g56 z offset 0.000 mm [g56a] g56 a offset 0.000 deg [g56b] g56 b offset 0.000 deg [g56c] g56 c offset 0.000 deg [g57x] g57 x offset 0.000 mm [g57y] g57 y offset 0.000 mm [g57z] g57 z offset 0.000 mm [g57a] g57 a offset 0.000 deg [g57b] g57 b offset 0.000 deg [g57c] g57 c offset 0.000 deg [g58x] g58 x offset 0.000 mm [g58y] g58 y offset 0.000 mm [g58z] g58 z offset 0.000 mm [g58a] g58 a offset 0.000 deg [g58b] g58 b offset 0.000 deg [g58c] g58 c offset 0.000 deg [g59x] g59 x offset 0.000 mm [g59y] g59 y offset 0.000 mm [g59z] g59 z offset 0.000 mm [g59a] g59 a offset 0.000 deg [g59b] g59 b offset 0.000 deg [g59c] g59 c offset 0.000 deg [g92x] g92 x offset 0.000 mm [g92y] g92 y offset 0.000 mm [g92z] g92 z offset 0.000 mm [g92a] g92 a offset 0.000 deg [g92b] g92 b offset 0.000 deg [g92c] g92 c offset 0.000 deg [g28x] g28 x position 0.000 mm [g28y] g28 y position 0.000 mm [g28z] g28 z position 0.000 mm [g28a] g28 a position 0.000 deg [g28b] g28 b position 0.000 deg [g28c] g28 c position 0.000 deg [g30x] g30 x position 0.000 mm [g30y] g30 y position 0.000 mm [g30z] g30 z position 0.000 mm [g30a] g30 a position 0.000 deg [g30b] g30 b position 0.000 deg [g30c] g30 c position 0.000 deg
Ive got movement in all axis’ now but its milling the test chilipeppr inverted on the mdf
