Does anyone have a lead on the closed loop belts needed for the Herculien? the only ones I can find are at sdp/si and are out of stock until late june
Robotdigg has them.
Which closed loop belts? For X and Y or for Z?
Between Motors and Side Drive Rods: http://www.robotdigg.com/product/282/228mm-or-232mm-length,-6mm-width,-Closed-loop,-GT2-belt#
For Z Stage: https://www.adafruit.com/product/1184#
These are the links provided in the HercuLien BOM: https://github.com/eclsnowman/HercuLien/blob/master/BOM/HercuLien_BOMV3.pdf
If you click on the prices in the PDF most will take you to links for the products.
doh, I was working off of the XLS and it doesn’t have links for those items. thanks for the leads
The XLS does as well, that’s what generated the PDF
ID10T Error… Lookie, there’s another tab
