Does anyone have an x/y axis belt tensioner bearing block that will fit my flanged self centering sintered bushings. They are for 10mm rod and have an OD of 16mm.
If you provide all the dimensions we can get one modified for you.
Thanks @Eclsnowman I was just seeing if there was already something out there that was already made up. I starting designing my own using Fusion 360. Wanted to get use to the software anyway. I use Inventor at work and have used Solidworks for the past 20 years. This will also give me a chance to see what measurements I have to design to that will print the measurements that I need for press fit bearings and such.
