What setup do you already have?
You can definitely use FastLED to help write a color fade.
What’s the current hardware and software that you have running already?
U could convert your starting hue and your goal hue to RGB with FastLED’s integrated libary hsv2rgb.h and then u could make a RGB fade. But im not sure whether FastLED is made for analog stripes…
Thanks All. I’ve been working off the analog example but am not clear on how to fade colors between the showAnalog command that aren’t next to each other on the hue spectrum/rainbow.
You could set up your start color and end color, and then loop a variable from 0…255, calling
CRGB c = blend( start, end, loopvar);
and then just “analogShow” the blended color c.
If you use HSV colors, you get an HSV fade. If you use RGB colors, you get an RGB fade.
One trick I use is the Noise + Palette code (found in the examples folder):
I create my own color palette of whatever colors I want (could be a short hue range), and then change the scale to 1. It just zooms right in, so the effect is just randomly cycling through whatever colors you chose in the palette.
I think my main issue is comprehending what changes in the addressable examples to simplify for analog strips. I’ve tried implementing below but not sure what to put within the showAnalogRGB.
