Does anyone know if it’s possible to effectively 3d print one of those nylon
Does anyone know if it’s possible to effectively 3d print one of those nylon ball return pieces inside a ballscrew nut; SFU 1604?
I’ve printed PLA bushings. But had to go through a few iterations to get the tolerances right.
I may give it a shot, but I will likely try using nylon or similar filament. Ideally an SLA printer might get a more detailed and defined model, but I’m not sure and I don’t have access to one of those. I’M concerned pla would warp in heat.
I printed replacement parts for the inside of a dishwasher. A fairly hot environment. They outlasted the motor. Those were PLA. But higher temp plastics are better if you are worried about heat.
I may give it a shot with pla to see
I don’t think heat would be the issue. It would be the durability. But nylon may work well, I have never used it. Gonna get a roll here soon and try it out.
