Does anyone know if the student/home version of Corel Draw is compatible with Corel
Does anyone know if the student/home version of Corel Draw is compatible with Corel laser?
The Home version is not. The educational version is. The problem is that the Home version gets installed in a different directory structure and with a different executable name than the other versions so when you run the CorelLaser install that adds the add-in to the Corel toolbar it can’t find the registry and file system entries it’s expecting.
Also the K40 Whisperer program is another option to use with the stock controler other than the corellaser plugin.
http://www.scorchworks.com/K40whisperer/k40whisperer.html
