Does anyone know if UV resin is good for lost-resin molds? Will it burn up or melt at high temperatures without nasty residues ?
@Josh_Ellis1 (from MakerJuice), any idea?
I can’t speak for any other resins, but mine will burn out fine in a kiln and can be used for casting.
Epoxy resin will generally carbonize and burn out at high enough temperatures, but will give off nasty fumes.
“Don’t breathe this!”
You shouldn’t be breathing anything burning out of a kiln…
I saw this a while back – first thing I thought of when I saw your question: https://formlabs.zendesk.com/entries/24676618-Early-test-show-that-the-clear-resin-IS-lost-wax-castable- – although it’s encouraging, you will surely have to test the specific resin you are using.
