Does anyone know the default data rate when setting up Ws2801 strip with FastLED. (Wired to the hardware SPI pins)?
Have a look at the data sheet https://www.sparkfun.com/datasheets/Components/LED/WS2801.pdf It says the maximum CLK is 25mhz so anything below.
Thank you Daniel.
Thank you also Leon -
I was specifically looking for the default rate used by FastLED, which as Daniel has already mentioned is 1MHz.
